Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Sat Apr 15, 2006 8:04 am
It's a little more involved than that, but not bad. In addition to splicing in the RB's A/C clutch plug, you have to move the two A/C control wires from the KA ECU to the RB ECU.
The S13 works the same way as the S14. The only difference is that the S14 has a triple pressure switch while the S13 has a dual pressure switch. The 3rd switch on the S14 is used to control the auxilliary fan, which is unneccessary on the S13 because the fans are independently controlled. As with just about everything else, the S13 is quite a bit simpler and more straightforward than the S14.
IMHO the best system you can do is the one Nissan already set up for you. I did this on the S14, using the KA compressor with a custom bracket on the RB20 (with extended KA suction line and shortened KA discharge line). I bought a new dryer, cleaned out the whole system, replaced the compressor oil with mineral oil (much better than PAG or ester oils), and used Duracool refrigerant (better than R12). The new system works well and uses about half the horsepower of the equivalent R-134a system while cooling better. It is also very, very quiet. I think that is partly due to the reduced compressor load and partly due to the mineral oil.
So A/C is doable, but like in the other thread going right now, make very sure you have good ducting. Most people don't have the splash guard installed. Get it on.
