Daunttless »
https://forums.nicoclub.com/daunttless-u116.html
Sat Sep 28, 2002 2:40 pm
I wouldn't upgrade the turbo on a 3k budget, a turbo upgrade will cost half of your budget. : ) Fuel injectors will run like 500 dollars, then you need a fmic, thats like 800-1000, you'll want a clutch thats like 300, you'll need a fuel pump 129, you'll need fuel control with a low cost solution like apexi for 300, or a JWT for 500, or standalone for 1000+, you'll want boost control if you go electronic yer looking at like 400-500. That doesn't leave much room for a turbo upgrade. : ) You may as well upgrade everything else and while the engine is out do something like a metal headgasket for another 200, and then just upgrade the turbo and manifold later. Might as well put in a LSD for like 200-300, theres all kinds of other parts you should do rather than dropping 800-2000 dollars on a turbo + extra for a new manifold if you don't get a T25 flange turbo. Enjoy your day.
