cool man. yeah, that does help. a i called up a buddy of mine and he talked me through an easy way of doing it with a relay a fuse and a switch (just a simple series circuit) but i think i'm going to use the thermostatic switch that you mentioned instead of the toggle switch that i am using now. thanks for the help guys!martins_240sx wrote:I suck at wiring myself, but I went to auto zone or maybe it was kragen...anyways I got this thing called a thermostatic switch, it cost $15 it comes with instructions, to adjust all you do is turn it all the way to the hottest setting and then start the car, let it reach operating temperature and then start moving switch to the colder setting until the fan turns on, watch fingers...then you are done and can fine tune however you see fit...iv been running with this since last year, no problems....hope this helps
