Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Mar 01, 2005 1:26 am
Always change from bottom [on a lift] after removing belly pan. That way you get to clean up all the leaked oil with spray copious amounts [multi cans at times] of brake cleaner and examine all the undersides for replacement opportunities.
Presently driving a lot [3,000 miles per month] so I get to spend Monday doing car house keeping -- changing oil every 6 weeks and checking everything over. Surprised the Q, can still take it after the the last few years of benign low annual mileage.
Interestingly, now that I am back to conventional oil [10w30] and oem filter the engine still only loses [uses] < a quart in 4,000 miles [6 weeks]......about double the Mobil 1 in what was a 3 month period for the same 4,000 miles.
About to turn to 279,000 miles...........due to lots of idling - frequent starts BG44K and MOA-111 now at [or prior depending on product] every oil change.
This city/traffic idling is wrecking the system cleanliness [TB/plenum egr oily dirt] but with my high mileage to be expected [blowby from ring wear]
