Another discovery bout my CA
cjmirabal1
Car: Past: 90' S13 fastback
CA18DET powered
Current: 90' S13 fastback
Vh45de powered
made another discovery about my ca18det today
turns out im running a J60 maf (rb)...always thought it looked odd for a stock and knew it wasnt a z32.
not surprised because my motor came with a chipped sr20det ecu (62) and runs perfect.
i wonder what size injectors i have??
makes me wanna rip the whole thing apart to see what other surprises are in there....to bad its my daily.
just thought id share that!
I love this motor! :woot:
Spawn_CA18
Car: 1993 EDM Nissan 200SX S13 CA18DET & 1995 EDM Honda Civic Crx Del Sol EG2 B16A2
can you tell the colors of injectors? are they yellow or what? the color of plastic circle under the connector of injector
float_6969
Yea, if you give us the color of the plastic top of the injector, we can tell you if they're uprated. Chances are if they upped the MAFS, the injectors are increased as well. If i had to guess, they're probably 440's. What size is the turbo?
cjmirabal1
CA18DET powered
Vh45de powered
float_6969 wrote:Yea, if you give us the color of the plastic top of the injector, we can tell you if they're uprated. Chances are if they upped the MAFS, the injectors are increased as well. If i had to guess, they're probably 440's. What size is the turbo?
Ill deff look at the injector color asap....the turbo is the stock ca18 t25
cjmirabal1
CA18DET powered
Vh45de powered
checked out the injectors today...there pink or peachish cuz the dirt and grim lol
Spawn_CA18
i think they are 600CC RB26DETT injectors..
OR
DSM ones . like evo8-9
can you take a picture of it please?
cjmirabal1
CA18DET powered
Vh45de powered
Spawn_CA18 wrote:i think they are 600CC RB26DETT injectors..
OR
sorry for the cell phone pic (8mp evo! ftw lol)...its 92 degrees outside with no shade so i cant really pull the plug to get a detailed photo
will try on a cooler day!
Spawn_CA18
cjmirabal1
CA18DET powered
Vh45de powered
looks very similar!! if thats the case i would have never guessed that!
Spawn_CA18
i have same injectors on my CA..
if you need details of that inj. i can post it .
cjmirabal1
CA18DET powered
Vh45de powered
Spawn_CA18 wrote:i have same injectors on my CA..
that be good thanks....
now i wanna rip it all apart even more!!! whats internal is wats got me curious!!
if they are that sized injectors my care runs great mpg wise on stock pump and fpr
cjmirabal1
CA18DET powered
Vh45de powered
what do you think Float?
Spawn_CA18
here it is...
cjmirabal1
CA18DET powered
Vh45de powered
thanks
float_6969
I have the EXACT same color injectors. They are NISMO 550-ish cc injectors. You need a bigger turbo (T3/T4 hybrid), fuel pump, and boost controller. That thing will be a rocket. If you can't go that route, AT LEAST upgrade to an S15 T28. Trust me, you'll be glad you did.
cjmirabal1
CA18DET powered
Vh45de powered
float_6969 wrote:I have the EXACT same color injectors. They are NISMO 550-ish cc injectors. You need a bigger turbo (T3/T4 hybrid), fuel pump, and boost controller. That thing will be a rocket. If you can't go that route, AT LEAST upgrade to an S15 T28. Trust me, you'll be glad you did.
NICCCEEE :mike
yea i wanted to get a s15 t28, and run it all on nistune!
i like the bottom mount set up! at least while the car is still my DD!
i have a hallman manual boost controller on it now.... did u mean an electric boost controller??
thanks guys for all ur help and info by the way!! :bowrofl:
float_6969
The hallman is fine. Glad to help.
cjmirabal1
CA18DET powered
Vh45de powered
float_6969 wrote:The hallman is fine. Glad to help.
:bowrofl:
