another cruise control problem... any ideas?
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
well im working on getting my car back into shape. I've been trying to fix this problem all weekend and have been googlin like crazy! btw I have a 93 240sx stock engine / auto trans. anyways I press the cruise control button and the light turns green and i can hear the relay click. but i can't get it to engage. no light on the cluster. I've tested both relays, vacuum pump, switch by the brake pedal. I put a volt meter to the acsd box and its getting voltage. i disconnected the rear lights and the problem continues. is there anything else that could cause the system not to engage the c/c? thanks!
AeonTorpor
Car: 1991 Nissan 240SX SE
Have you checked the solenoid itself? It may be engaging electronically but the actuator may be damaged/malfunctioning. It's even possible that the cruise control cable is loose, causing it to not hold the throttle in it's proper position.
(armchair mechanic, take w/ grain of salt)
lrb_2000
Car: '91 Nissan KA-T hatch
Check your horn fuse... or I could be crazy.
NISSAN240SX12
1991 Toyota Supra
lrb_2000 wrote:Check your horn fuse... or I could be crazy.
I've checked the solenoid and its working. I hooked it up to a 12 volt source and like magic it works. I have a horn all good there!
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
just delete it.
who uses cruise control anyways
zenki-S13
Car: 1990 Nissan 240sx S13
^^^^agreedno need for itthe best way for you to fix it would be to delete itget that unneeded weight off your car (if the assembly even weighs much)
ocalas240
Car: 1992 Nissan 240sx
i had a similar probelm last year when mine was being stupid. it ended up that the vacuum hose had a small crack in it causing it to not hold any pressure. $1 fix for some hose and ta da!! she works!! it lasted a year or so until now, then it started crappin out on me again. so i just got mad and ripped the sob outta there.
