Another crappy 5 lug conversion ?
Drifter K
Car: Vid Games, Car shows, 240sx Tuning
To do a 5 lug conversion swap on an s14 can i just swap the hubs off an SE and no other parts needed? In some posts i read. They just said all they did was replace the hubs and then in some other posts they listed a whole bunch of other parts that totally confuses me.
I know in the end ill need the wheels. How about rotors? do i need 5 lug rotors too?
here are the posts that confuse me with the parts
Post number 1
Post number 2
Post number 2 by PSI240SX said all he did was replace the hubs and he was done
then psyclone69 said all he did was swap the rotors and hubs and he didnt use the spindles cause the spindles were ok and were not needed to replace to do the swap....
If i dont need much parts i was just gonna buy the hubs off a junkyard and replace, if i need rotors ill buy them too
Nismo_Freak
Car: 89 Nissan 240SX
You will need the rotors unless you'd like to redrill your stock 4-lug ones. Which I don't suggest.
Drifter K
Ok thanks nismo freak So ill just buy the hubs and i plan to upgrade the brake system with new rotors and calipers.
