Another coolant leak thread. Yay.
eisenfaust
So, summer has arrived, and with it massive overheating issues, right?
Anyways, my car (1992 240SX, KA24DE) has decided that it cant hold its water, and has developed a coolant leak.
My chief suspect is the water pump, but my symptoms are thus:
1: A coolant leak when the car is running. Seems to start about 30 seconds after the car does. A steady stream of coolant dripping down the block from the accessory drive area. My thinking is that the water pump is weeping.
1b: Stops pretty much instantly when the car is turned off, its constant when the car is running.
2: Intermittent heater function. I think this is down to the fact that the car is losing enough coolant that the core isnt getting any hot water. If I refill the radiator and bleed the system, the heater works fine until it runs low on coolant again.
2b: The first time I noticed the problem, I turned the heater on and nothing happened. No hot air. I then noticed that the temp needle was way up (though not pegged). A few minutes later, as I was about to pull over, the temp needle dropped like a rock and the heater started working again. Could this be due to intermittent water pump function?
That's pretty much it.
Mylast question is: is there a place where I can find a decent walkthrough on replacing the pump?
Thanks!!
ex_MGB
Car: Nissan Frontier
I crawled under my Frontier and it definitely has the water pump weeping. I too am searching for a water pump replacement walk through. I've searched high and low but to no avail.
Oh well...
TheOne
Car: 93 240sx FB
probably a FSM.
http://www.nicoclub.com/FSM/240sx/ <<has some fsm's.
ex_MGB
That definitely did the trick and then some
