highspeed »
https://forums.nicoclub.com/highspeed-u53523.html
Tue Jan 23, 2007 2:40 am
So check the engine timing or ignition timing? I think it is something else because it will not start for 10-13 cranks then it will just start right up without any hesitation. The only clue to some other problem is the constant high idle at every red light even when the car is warm. Every once and a while the car will idle down but it usually only happens once or twice a day if at all. Also at idle it kind of skips. So maybe it is ignition timing. But once the car is warm it starts fine until it gets cold again. This is my first sr20det and 240 so I might need some pointers in getting the timing adjusted. Thanks
