Another coil question..
redcobrar
My ma has a super clean 1999 Q45. About two weeks ago the car stumbled at idle and the check engine light came on... and it's staying on...
We took it to the dealer and they told us its the coil for the No 1 cylinder that is causing the trouble and it needs to be replaced at 400 dollars along with the rest of the 7 coils.
My question to you guys, i was looking on line and I found that i could buy a coil for 112 bucks from autopartswarehouse.com so does that coil fit all 8 coils???
Also, besides new spark plugs is there anything else that I need to do this job by myself??
http://www.autopartswarehouse....+9224
Q451990
Skip autopartswarehouse and go with Joe! You get guaranteed OEM quality and great customer service. He's having a sale that makes them even less than $75 each. Check out the thread in the Q45 forum for the discount code.
http://www.infinitipartsusa.co...gid=0
I would only use OEM NGK plugs.
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You need the FSM and a good torque wrench.
Clear the codes in the ECU and switch the coilpack. When a code is thrown again, if it follows the coil pack, that coilpack is at fault and you just need to replace that one, not the other 7 also.
http://www.nicoclub.com/FSM/Q45/
Use the specified NGK PFRG plug only! Unless you are in the desert, probably 5 for you.
redcobrar
Whats a FSM and I know you sent me the link for the manual (thank you) but is is hard to clear a code?
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
You don't need anything special here, just replace that coil and only replace the sparkplugs if they are due or close to the end of their life.
Don't touch the other coils unless you plan on replacing them-there is no evidence of this yet but pulling old ones off may cause them to fail earlier.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
redcobrar wrote:...but is is hard to clear a code?
Not with a decent code reader.
