Another Coil-over question
apollo500
Car: 1996 Nissan 240SX SE
i know there are many threads about coil overs for s14's, the reason i am posting is that i could not figure out what i should do from my hours of searching the threads.My car is a 1996 240sx SE, it is stock except for some bolt-ons, for now....The car will get a 5-speed swap this year, the ka24 will get a turbo installed next year. my budget will allow me to spend about $1800 on suspension and wheels this summer.The problem is that i need some coil overs which will provide me with some comfort because this will be my daily driver, and will be good enough to do some drag runs, and some road racing. i am planning on putting down between 300-350 HP when i'm done with the turbo, can someone give me some advice on what coil overs would be the best for me, i'm not really into playing with the coil overs, but want the height adjustability.
Slappy
Car: 1993 240 sx coupe
TEIN Basics or Tanabe Sustec S-OC Type II if you want a quality and affordable height adjustment only Coilover.
http://www.tanabe-usa.com/coilovers/s-ocII.asp
http://www.tein.com/products/basic.html
Incase you have coilovers like Tein Basics or Tanabe Sustec S-OC Type II , you will need either optional Upper Pillow Ball Mounts or Camber Bolts. Camber Bolts will also work on your Spring/Shock combo.
Cusco Upper Pillow Ball Mounts
http://www.injectedperformance...ID=34
H&R Camber Bolts
http://www.optionsauto.com/pro...TC112
Stripes
Car: hatch, coupe
yea man i second that with slappy. i wanted the same for my car and i went with tein basics and threw some pillow ball mounts on there and they are great.also, i myself don't know much about kts' but i've heard from people who have had experience with them that they are a good mild coilover as well. whatever you end up with i'm sure you won't be disappointed.
apollo500
thanks, a lot, i will most likely got with the tein basics, which i was considering from the beggining, i will likely buy the pillow ball mounts also, thanks again
Slappy
Your welcome
Endura-Tech
Suggestion PM'ed.
adrianfromthecastle
Car: 1992 Nissan 240sx
Endura-Tech wrote:Suggestion PM'ed.
since when does Nico have a PM function?
Endura-Tech
Well, emailed.
adrianfromthecastle
LOL...
