Chezedik wrote:I have spark and am almost certain I have dizzy timing right (although it wouldn't matter, read on).
Can't guess at this. It has to be perfect or at least +/- 30* either side of TDC to even attempt to run. If you have spark ,fuel, and compression, your timings off.
Compresson readings on a new built, never run engine won't tell you much, depends on the assembly lube they used (which should just be a light oil or graphite, not grease - though grease would certainly give you high compression readings). Maybe the un burnt fuel has washed away all the lubricant in the first three cylinders and no. 4 will go next. Or, No. 4 cylinder isn't spraying. Still wouldn't keep the engine from firing.
I'd double check the timing, as it does matter, pull the plugs and clean them with something like CRC Electro Clean, pull the fuel pump fuse and crank it over w/o the plugs to make sure your oil pressure light goes out or you have pressure if using a gage and to blow the flooded mixture out of the cylinders. ( EFI engines will rapidly flood if they don't immediately fire.)
Install plugs and fuel pump fuse and crank again, this time using 5 second burst on the starter. If it doesn't catch right away but sounds like it wants to after a couple of tries give it 1/2 to 2/3 throttle while cranking and immediately back off if it fires. Next time you go to light it off you won't have a problem as all the fuel lines and FPR will achieved their normal operating state.
Good Luck
