Long story short, we blew the motor so we swapped it out for another ca18det that was running and came out of a wreck.
The problem im having ( at least i think it is ) no injector pulse to the injector plugs, All we have done is swap ca18det for another ca18det, all the wiring is the same and nothing has been changed or cut / spliced from last time...
Fuel pump works -
Checked this by taking of the feed line and it sprays fuel when ignition is on
The fuel rail is not blocked
I removed the rail, and then the injectors, turned extended the feed and return fuel lines and moved the rail outside the engine bay, when ignition is on the rail does fill with fuel.
Injectors are NOT blocked -
Took injectors out and they click and squirt fuel when provided with a direct power source
Drop down resistor harness is getting power but not sure if there is continuity to the injector harness -
When connecting 1 end of the test light to the middle wire on the harness from the car ( the white wire out of the 5 wires ) and the other end of the test light to a ground, it lights up.
I plug in my resistor pack, cut a little bit of the white wire on the resistor pack end and it lights up also, so does this mean the pack actually IS getting 12v? So its not a faulty resistor pack ?
Should i also be seeing continuity if i put one end of the test light on the injector plug and the other end on 1 of the 4 signal wires from the resistor pack ?
Engine isnt broken -
Engine used to run fine, and the car does fire for a few seconds if i spray some fuel ( or a can of "START YA BASTARD" into the throttle body.
I have tried 2 resistor packs so far, and 2 ECU's with the exact same problem, Could i be so unlucky as to have either blown 2 resistor packs or 2 ecus ?
Can i bypass the resistor pack ? I tried splicing all 4 signal wires on the pack, and then supplying the white wire with contact 12v and still have the same issue.
Any help would be much appreciated.
