blknismo180 »
https://forums.nicoclub.com/blknismo180-u76573.html
Sun Jan 24, 2010 9:01 pm
so today i noticed my brake lights weren't coming on but my taillights were.i already checked the fuse to the taillights, checked the plastic grommet, and i checked to see if the switch was working right, and all of it was fine. i took an old test light and it seems as if the switch is not getting power, i took a test light and it did not light up to either wire.
the only things i messed with electrically today were: moved around stereo (loose wires are tapped off), i soldered my window amp, i tapped on a wire to my speaker because the connector broke.
any advise will be helpful thanks
