esahuque »
https://forums.nicoclub.com/esahuque-u20709.html
Sun Nov 18, 2007 8:20 pm
Well i blew my motor tonight, need some opinion's
Lets start off by giving you the history. 95 240sx, bought the car with a cracked head and swapped the motor out with a 96 motor with 62,000 mi on it. Did a compression test and got 170ish across the board. So I went ahead and turboed it with a sweet t3/t4 turbo, 550cc injectors, enthalpy tuned ECU and a SAFC NEO all dyno tuned ( 11.5 at WOT). This morning i started my car and it had a slight miss to it (sounded like i was driving a VW) and it was idling a little lean, about 16.2 when i usually idle a 14.7 to 14.9. tested a few sensor's did a boost leak test and check plugs and wires (PLUGS LOOKED PREFECT) couldn't find anything wrong. The only thing i wasn't to sure about was the voltage test on the n62 maf, wasn't sure what the voltage should be. It was 0.7v with the car off, 1.0v with the car at idle and 2.15v at 4000 rpm's. anyway i went ahead and took it for a spin, it was running at about 13.5 to 14.1 under light load and about 12.5 to 12.9 at WOT. So after i did my pass i let off the gas to stop at a light and it killed. It took a good bit to get it started again. after that it wouldn't hold an idle, so i limped it home and popped the hood just to find...........Oil all over the motor, I getting BAD blowby out my breather on my valve cover. I'm going to hopefully rebuild the motor, if i can but my Question is
How can i tell what caused this? i would hate to rebuild the motor just to find out that my tuned ecu caused this or bad maf ect ect... and blow the motor again.
just looking for some advice as in what to look for when i open up the motor in what may have cause this healthy motor to go out this fast. i only put 2000mi on the turbo
sorry for the long post, thanx in advance
Modified by esahuque at 10:31 PM 11/18/2007
Modified by esahuque at 11:06 PM 11/18/2007
