GoTRicEo0 »
https://forums.nicoclub.com/gotriceo0-u37733.html
Thu Oct 22, 2009 12:12 am
Open loop or not. The AFC will modify the MAF voltage and send it the ECU. So... if the O2 sensor was unpluged. You would be modify it in limp mod. The ECU will still be in its failsafe mode, while the SAFC will tell it something completely different. No matter what setting you put. The ECU is already in fail safe mode and that pretty much makes the SAFC tune pointless. Fool the ECU into thinking there's an O2 Sensor there or tune in limp mode. Might as well install the O2 Sensor + Wideband combo instead of O2sensor delete. Cheapest way out.
Unless you go independent fuel management.-Jeff
