Another antifreeze leak......
fabio240
Car: S13 with ca18det
Ok so Im driving my car as happy as can be and I start to smell coolant so I pay it no mind Im thinking overflow tank so when I get home I check and the leak is on the exhaust side any IDEAS as to what could be leaking coolant over there?
progman
Turbo!!
Nali
Car: Datsun Nissan 280ZX
progman wrote:Turbo!!
Quoted for truth.Most likely ur turbo lines are cracked if ur running on the stockers. Else just give them a good once over.
fabio240
I hope so cuz its on the block can I just block the lines off?
rico05
Car: 1992 RMS13 w/ CA18DET
When I had coolant on the block on the turbo side, it was a head gasket let. You need to get under the car at full hot and take a look see. But, do not block those lines unless you want to kill the turbo if that is in fact the issue. Those lines are steel, so I dobut that they are the issue, however.
239s13
check the freeze plugs
mbmbmb23
Take your car to a shop that can pressurize your coolant system and see where it leaks as its leaking. Could be the headgasket...might as well find out for sure by being thorough.
-m
fabio240
rico05 wrote:When I had coolant on the block on the turbo side, it was a head gasket let. You need to get under the car at full hot and take a look see. But, do not block those lines unless you want to kill the turbo if that is in fact the issue. Those lines are steel, so I dobut that they are the issue, however.
Any kind of way to fix that without pulling the head off?
mbmbmb23
fabio240 wrote:Any kind of way to fix that without pulling the head off?
If you HG is not sealing its either the HG or the head is warped. Either way, head needs to come off.
