Another Altima stuck in the "Park" Lane
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
One day you start your L33 Altima or R52 Pathy and find yourself stuck in Park. You get a screwdriver and use the mechanical release, and for days or weeks it's fine again. Then it does it a second time. The problem grows more frequent as time goes on...
Here's the fix: https://www.nicoclub.com/archives/help- ... e-fix.html
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
Yep. You can add the Nv200 (Nissan's mini minivan) to that list. I work part time for a truck dealership that has an NV200 as a company car. Same problem happened at around 40,000 miles, I ended up using a slotted screwdriver thru that small circular access point to nudge it out of park for a couple days until the shop had a chance to fix it. Can be very annoying.
VStar650CL
Technical Expert
Bubba1 wrote:
Sun Jan 10, 2021 11:54 am
We see the same issue on virtually the whole Nissan line, although most frequently on the L33 and R52. I should point out that the switch and the repair is similar for virtually all models. The location and type of actuator will differ, but they all use a molded, detachable switch carrier with the same type switch.
PapaSmurf2k3
Site Admin
Can you remove the system entirely?
VStar650CL
Technical Expert
PapaSmurf2k3 wrote:
Tue Jan 12, 2021 4:16 pm
Yes, but you can't just disable the switch. You either have to disable it mecahanically by wedging or removing the lever, or electrically by jumping the switch and connecting the solenoid to keyed power instead of battery.
