Another Altima AC Problem
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
texalt
Here is the scenario - AC suddenly stops cooling. 2002 Altima. Dealer shop investigates, concludes problem is electrical, and the culprit is the IPDM. IPDM replaced, AC is cooling for about 20 minutes. Before I can even get there to pick up the car, they call me back to tell me that suddenly the AC has stops cooling because the clutch on the compressor has just seized! The service department tells me that both of these expensive parts have failed. Cost to me: IPDM at 500 bucks, and compressor another 500 bucks, plus labor which is another 500 bucks or so. Plus tax, supplies and anything else they can find a way to put on the bill.
So, what are the chances that the IPDM stops sending power to engage the AC compressor, followed 20 minutes later by a failure of the clutch itself. Next to nil I suspect, I would be more likely to win the lottery (if I was stupid enough to buy a lottery ticket). Much more likely is that the technician misdiagnosed a problem with the IPDM, swapped the part at my expense, only to discover the actual problem was with the compressor all along.
I am not going to pay this bill happily. I would be grateful for anyone else's experience on knowledge on the subject to help me see the light.
atl530i
Car: 1994 BMW 530iA
2001 Nissan Altima
I would find a used compressor for the car. Screw the dealerships, they are good for getting cars, but when it comes to fixing car, they are rip off artists. You should DIY and save the $500 labor charges.
RICERMAN
At alot of dealers they try to figure out What you will pay to have the problems fixed more than what will it take to fix it......see what I mean The more you pay means the more they make. they are there to make money first and fix your car second.
Return to “3rd Generation Altima Sedan (2002-2006)”
