Postby
sr20_sil80 »
https://forums.nicoclub.com/sr20-sil80-u9506.htmlMon Aug 18, 2003 12:04 pm
Ok i have read up everything possible on the a/c with an sr20. and i hooked everything right. the thing is when it comes on it will work great and blows cold. but when im driving and i stop at a stop sign. the engine stumbles and almost dies. as soon as load is taken off the eng the car almost dies with the a/c on. i thikn it has something to do with the IAV valve but i am not sure how to fix it. please help
Postby
RobDET »
https://forums.nicoclub.com/robdet-u7114.htmlMon Aug 18, 2003 12:04 pm
I eliminated AIV however it sounds like the idle might be too low. Also you should check to be sure the BOV is adjusted right and make sure you have no vacuum leaks.
Postby
sr20_sil80 »
my idle is stock. and if everything works right it shouldnt have to be raised. i know i can raise it but i'd like to actually figure it out without raising it. i hate living in AZ with no a/c
Postby
RobDET »
Did you set it properly? Unplugging the TPS and all?
Often Modifications can throw your idle off some. CAI or Exhaust exc... Even Slight timing / fuel Adjustments can screw the idle all up. And the ECU is pretty good at making you think it's ideling correctly.
Start the car/ Warm it up/ Unplug the TPS and see what happens to the idle.
