240TweakerNewbee wrote:I know for a fact that S14 rotors will work perfectly with the rear 5 lug swap, the front I'm not 100% because Im not actually running them on the front, but why not just (do like me) go with early 90's 300ZX Twin Turbo calipers and breaks for the front, and stick to s14-5lug on the rear; pick up a set from
http://www.rockauto.commay I suggest the master cyl too, and some break lines... I know its a bit on the pricey side if you add it all up, but how important are breaks at 100mph down a hill making turns. But then I drive it like I stole it and my hair is on fire
S14toRPS13 wrote:I need new rotors anyways and after buying the 5 lug parts I'm not gonna have much left over.
If you search, you'll find that fronts work just fine. Its the rear that's dependent on what type of hub swap you're doing.
Like I said, bare minimum, get new rotors and quality pads and you'll be good for daily driving and the occasional autocross or track day. Unless you're planning on tracking the car heavily, which I'm doubting, you won't have to worry about brake fade or anything. Stock calipers are fine.
