240Kuminachu »
https://forums.nicoclub.com/240kuminachu-u946.html
Mon Aug 30, 2004 7:14 pm
Sorry guys, I need input on this.
I got the coolant issue resolved, For now. Thanks.
So my turbo hasnt pushed past say 4.5 PSI, since I've had the car. It pulls prety tho, I kept with a WRX a few nights ago in 2nd. Im reading my Boost of the SDS Manifold presure gauge, I've been told thier not too accurate but Im not sure, thats what im going off.
Also with the window down the turbo seems to make alot of noise, say, comparable to a desiel turbo enigne. Almost like its leaking and spooling to hard, at that point it makes some hideous noises too, like its spinning to fast. Im not a turbo expert so I need suggestions.
Two of my friends had boost problems also, It turned out to be the gasket between the turbo and the header or manifold on the block, I took it apart tonight with a replacement but the gasket is fine, so thats not it. All other gaskets are solid. The only other thing it might be in my mind is the wastegate, its the stock one, so it could be bad.
What does a bad wastegate act like? The BOV sounds prety loud and crisp when I let off. Greddy Type-S. (very sexy)
The turbo has minimal shaft play side to side. Minimal. And the fans are in great shape with no nicks or anything. Also there is a pin whole on the bottom half of the wastegate, It looks like its supposed to be there but again im not sure. I can see the shaft thru it, again its on the bottom half, it should'nt effect anything right?
I think thats all. Ideas Please. Thank You.
Also, what is an easy way to presureise the system to check for leaks.
Thanks!
