annual flush
captainluigi
Car: 1996 q45t
just got my Q from my tech. i had the trans flushed with the bg machine & the bg syn fluid installed. what a difference that made. previously with the dino fluid (chevron) there was the ususal 1/2 firm shift then a muddy 2/3 shift then an unnoticible 3/4 shift. now i need to watch the tach to tell the shift points (normal driving). even the torque con. lockup is unnoticible. on hard accel. it shifts sooooo smooth. definetly worth the $200. highly recomended.
goody90q45
Car: 1992 Infiniti Q45 (sold)
captainluigi wrote:Just got my Q from my tech. I had the trans flushed even the torque con. lockup is unnoticible. On hard accel. it shifts sooooo smooth. definitely worth the $200, highly recomended.
I also had a transmission flush done last week. I've been draining and refilling with each oil change and finally put out the $200 for a chemical flush and fluid exchange to Valvoline synthetic. Also dropped the pan and changed the filter. The (minor) rough shift from 1>2 gear is gone and no more slipping between the other gears. Money well spent if it extends the life of the transmission.
Babyboy11
Car: Q45t
Hey, I just got my transmission replaced on my 94 Q. The new one has 71k miles on it and does shift hard between second and third.
Question: Are you saying that if I change the brand new transmission fluid that I have in my transmission with high end fluid that it will do away with that rough shift? Also, will that rough shift between 2/3 damage the transmission? Thanks
Rex
Car: None
Babyboy11 wrote:Hey, I just got my transmission replaced on my 94 Q. The new one has 71k miles on it and does shift hard between second and third.
Are you getting any Transmission Malfunction errors?
FWIW, I was told by a knowledgable transmission man that if the clutch plate materials aren't specifically designed for synth transmission fluid, you're not really getting the benefit of synth ATF???
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No pan drop, inspection and cleaning, filter and gasket replacement?
captainluigi
Car: 1996 q45t
the above was a given + changing the magnifine under hood filter.
