MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Fri Mar 09, 2007 3:15 pm
It is probably a power steering issue and not a belt issue.Check your power steering fluid. If it hasn't been changed in a long time, you may want to do that. It may just need to be topped off.Keep an eye on the fluid level for a couple of weeks and see if there are any signs of leaks. If there are, I recommend you get them taken care of pronto.
Running power steering with low or leaking fluid can cause all sorts of nasty problems which tend to escalate and become expensive fast, so make sure you keep on top of it.
