Ca_Silvia wrote:I think you are very very wrong about the knock sensor. When my knock sensor started f***in up, my car barely drove over 4000rpm. When the coils go all it does is trip a misfire code.
There is no mass Nissan cover up for misfires/knock sensors problems
This is how Nissan describes the Knock Sensor.
The knock sensor is attached to the cylinder block. It senses engine knocking using a piezoelectric element. A knocking vibration from the cylinder block is sensed as vibrational pressure. The pressure is converted into a voltage signal and sent to the ECM. That is from a Nissan Dealership Assist program that the techs use here at the Nissan dealer I work for.
It also explains on this bulletin that if you have a drivability problem such as a coil or injector, or even an O2 sensor, and you have retrieved a knock sensor code from the ECU, then start with the drivablility problem, then if that doesnt fix the knock code then the sensor has high or low voltage (which would also pop up a code that would say knock sensor High/low voltage) and the sensor has either shorted or has an open circuit. Which then, replacing the sensor would be ness. but only if the code is read "knock sensor circuit high/low voltage" should the knock sensor be replaced or check the wires to it.
I work at a Nissan Dealership, in the parts department and see this happen 3-4 times a day. We NEVER replace the knock sensor, and I have saved a few local shops some aggrivation from having to changing them, in some of the new pathfinders, they are under the plenum/intake.
Wouldnt have said it if I didnt know it to be true and see it every day. But, no one ever agrees with me so...
