Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Dec 13, 2003 1:04 pm
When were the oxygen sensors last changed, sometimes the closed loop to open loop transistion can be like a lean stumble.
What is the amount [duty cycle %] of the IAC at idle?
What is the block learn [% of basic fuel map correction on each bank]...........the O2 can correct +-20% from the ideal as new number].......dirty injectors, dirty TB, deposits on valves, pistions, SMALL vacuum leak, etc..................egr not shutting down fast enough [sticking]..............plus the cam advance solennoids. [noise?].
Tiny problems in transition are sometimes time consumming to find.
