Annoying! AC/Heater temp motors?
DMan II-40
Car: 1995 240SX SE
So first off I have an S14 (1995). When I change the tempurature of the air from the fans, ac, or whatever with that slider thing I hear this clicking noise from inside my dash. Someone before said it is probably plastic gears that have worne down and are slipping.
Anyone know anything about this?
I don't really want to rip my dash out to try and fix something I don't even know what it is.
wrightme43
Car: 1991 240SX SE, 5sp, Super Black
Its called a blend door motor and its behind the glove box.
Doya
Car: '95 240sx KA-T
Mine does the same exact thing whenever I change the vents to like floor or defrost.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
Same here... I've gotten used to it.
Doya
Car: '95 240sx KA-T
Steady_One_S13 wrote:Same here... I've gotten used to it.
Yeah mine doesn't do it if I keep the Floor/Defrost button pressed.
DMan II-40
Car: 1995 240SX SE
wrightme43 wrote:Its called a blend door motor and its behind the glove box.
To me it sounds like it is coming from the middle of the dash and in the back more, like close to the firewall.
Also it doesn't do it when I change where the air is coming from, only when I change the air temperature.
wrightme43
I will look on alldata tomorow at work and check man. The one on mine that was messed up, kept sticking in defrost. If I remember right the heat/cold deal is cable operated, and then uses a electric signal to turn on the compressor. The cable opens and closes a door (partial split or full heat or cool) and the blend door moves in different directions to determine air flow. Sorta like this|\ __ / different angles to determine how the air is directed.
DMan II-40
Car: 1995 240SX SE
Ok makes scene. Let me know what you find out, I really want to check this s*** out. Never taken the dash off before so it will be a fun project.
wrightme43
yours is different than mine.
I am going to try a screen shot of what is what.
wrightme43
http://alldatapro.com/alldata/...65986
it seems to be all locked man. I cant get it to what I want. You will need the FSM
wrightme43
yours has a power servo for the air mix door, and it looks like vacum actuator for the rest.
I wish my scanner worked and I would just post you a picture. Sorry again man.
DMan II-40
Car: 1995 240SX SE
no problem. Ill have to try and pin point the area of the noise then look at Diagrams and stuff.
