I understood you, you helped me! Thank youVStar650CL wrote: ↑Sat Sep 04, 2021 6:07 amYes, the BCM will do the 20-flash-and-then-solid thing (hardware error) and the lamp will be lit constantly. The clusters aren't terribly difficult to take apart, you can lift the fascia and stick some black oaktag over the LED. I've done that for several customers who were in your position with older vehicles. Don't use paint or marker, it's almost impossible to lay it on thick enough to blot out the light.
https://www.novuspolish.com/fine_scratch_remover.html
The tape isn't ugly, it's invisible. You put it underneath the fascia (the part with the silkscreens), not over it.
