and the results are in(compression)....
TK_Encore
Car: 1990 240sx
so all 4 are reading around 120 sooooo yea....gonna take it apart in the morn and take a look at the gasket. its a SOHC, but it should be reading at least 150 am i right?
s14derrick
Car: 1995 nissan 240sx
120 accross all cylinders? thats not good. i think 150+ is decent. are the numbers close?
jr_ss
Car: 95' S14
Having them all reading the same across the board is better than having one low cylinder..
TK_Encore
Car: 1990 240sx
s14derrick wrote:120 accross all cylinders? thats not good. i think 150+ is decent. are the numbers close?
sorry if i misunderstand but, are what numbers close? all 4 cylinders? yea they were all floating in the middle of 120-125ish area
Rosco
Car: 91' SR'ed Hatch
Sounds like you did a "cold" compression check....If so you should be fine.
Chris28
Car: 92 s13 KA-T
As Rosco said, warm it up then do it.
Your numbers are better than mine, I had 170-180 across the board then 115 in cylinder 4. A new KA was sourced after that.
dtowndrifter
Car: s-14 kouki
yup... looks like a cold test...with tb closed....probably bump up some if you squirt some dw-40 and do a wet test on a couple of cranks....i dont think you should worry...
at least its 120 across the board, and its even..
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
dtowndrifter wrote:yup... looks like a cold test...with tb closed....probably bump up some if you squirt some dw-40 and do a wet test on a couple of cranks....i dont think you should worry...
The 120 just means you can run more boost now....
TK_Encore
Car: 1990 240sx
wow nobody told me i should warm it up .........figured my friend would know about that. so maybe ill retest it before i take it apart. but im really hoping its the gasket, because thats not to hard of a fix
TK_Encore
Car: 1990 240sx
correct me if im wrong, this is TDC right?
