And so it officially begins...
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
SuperHatch
Car: 96 TLC
Finally got started on my project... just a few pics.
Just thought I'd share...
- Steve
Raxephon
Car: '04 RX8...for the moment...
Are those '94+ motors?
Just curious, but I noticed the single port intakes and the valve cover studs on the heads.
SuperHatch
Car: 96 TLC
One is a 94 T/C motor, the other is a std. 92 motor. The 92 motor had skipped time and I picked it up for spare parts/sensors. Little did I know pretty much nothing is the same between the two.
SuperHatch
Car: 96 TLC
A list of things I've noticed different between the two motors after diassembling them.
Block:92 - Mains are Studded, 94 - Mains are boltedCoolant drain plugs are different
Heads: 92 - Siamese intake ports, 94 - Oval intake ports92 - Valve Covers are bolted w/ RTV, 94 - VC's are studded with gasketsCasting within the head is visibly different92 Valve covers have a removable panel, 94 don't
Intake Manifold:92 - Siamese runners, 94 - Oval runnersVacuum lines are routed differentlyValve cover vents are vented in different positions
Electronics:CAS is differentCoil Packs are differentIgnitor chips are different
I'm sure there's more that I'm not remembering at this time...
SuperHatch
Car: 96 TLC
If I buy a full engine rebuild gasket set for a 94 motor, what will it include???
Head GasketsVC GasketsIntake Manifold GasketsThe rings between the upper and lower manifoldThrottle Body GasketWater Pump GasketThe O-Rings between the oil pump and blockThe O-Rings Between the Oil Filter Housing and BlockT-Stat Housing GasketsValvestem SealsFront Main SealRear Main SealMiscelaneous o-rings and gaskets I'm forgetting about....
I basically need to know if it's a "true" overhaul set with absolutely every rubber/paper/metal gaket and seal in the motor. I know for other motors this is true...
Will the head gaskets be composite or MLS? The stock stuff was composite, but I've heard people talk about MLS gaskets...
Thanks for the help guys... I will be purchasing through Infiniti BTW, stock stuff seems to be the best.
David Steele
Car: S13 FastBacK
When did they stop comming with siamesed heads?
I'd like to know because I'd want non-oval port motors, I plan to get serveral other Vh45's
David Steele
Car: S13 FastBacK
One more thing...
How are you hanging that crank ? lol You have a pulley bolt on the other side of that plank?
SuperHatch
Car: 96 TLC
David Steele wrote:When did they stop comming with siamesed heads?
From what I hear, the siamesed heads were produced until 93, the same time the crappy chain guides were produced. The motors were revised in 94.
SuperHatch
Car: 96 TLC
David Steele wrote:One more thing...
Yes, the puilley bolt is going through the plank with the washer so it doesn't pull through. I wasn't sure how long these motors will be apart and it isn't good to store a crank on it's side for prolonged periods of time. That is white oak and there are 12 decking screws holding it up. It isn't going anywhere.
defrag010
Eventually, would you be willing to sell the '92 block and crank and possibly heads?
SuperHatch
Car: 96 TLC
defrag010 wrote:Eventually, would you be willing to sell the '92 block and crank and possibly heads?
Buy a set of Rods in my group buy thread and I'll give them all to you... you just pay shipping,
SuperHatch
Car: 96 TLC
Got pics of the car my engine will be going in... just brought her home today. 1995 240SX Base Model Auto 101k miles.
Enjoy!
hannibal
Car: Red Line to Glenmont
Good looking chassis for the swap. I <3 black zenkis!
Youre keeping the VH automatic right?
SuperHatch
Car: 96 TLC
Yes, but not the stock trans.
Florida240sx
Which transmission you using? I'm starting my swap next month... I had planned on stock transmission but your using something else...
SuperHatch
Car: 96 TLC
GM TH400, no stock auto trans built or not will hold 1000+ HP.
Florida240sx
adapter plate??
SuperHatch
Car: 96 TLC
Florida240sx wrote:adapter plate??
Yeah, workin that out as we speak. I'll have more info over the next couple months.
Florida240sx
I need 2 of them. one fo rmy vert and one for my shop's g35 Let me know about it. Starting to source parts now for both swap.
Return to “VH45DE / VK45DE / VK56DE Forum”
