USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Tue Jul 01, 2003 3:19 pm
It's all out and nice and pretty. The only that that got ugly was the piping from the exhaust to the EGR. It wouldn't clear the steering shaft and I couldn't get it loose, so I busted out the dremel. But its all in one piece all ready for ya.
Also.... Doesn't look like I can use the CA AC compressor. Only the High Pressure line fits, the low pressure line, the fitting is too big to fit into the compressor. I am going to take off the KA compressor and see if it lines up with the CA bracket. Also, if I want to keep the power steering, it looks like the AC may have to be ditched, the lines are all goofy and have to be routed around.
Also.... when I change over the wiring... do I rewire the car side of the harness or the motor side of the harness?
Joe
