masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Fri Mar 11, 2005 8:18 pm
The analog tach is slightly larger than the digital tach. You can make an analog tach fit a digital cluster (with scissors) but not the other way around. Also, be sure you are sourcing a SOHC cluster, because the DOHC tachs don't read the SOHC signal.
The glow gauge shows a 7000 RPM redline because it was designed to go over the DOHC tach. The DOHC (DE) engines supposedly rev higher, but whatever. You know your engine's redline, so the tach doesn't have to.
And one more thing, the JDM S13 Silvias and 180SXs are pretty much the same on their top trim levels... except that one has a trunk and fixed lights while the other has a hatch and flip-ups. With the occasional exception of optional hardware (i.e. the digital cluster), they are 99% identical.
