masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Tue Jan 25, 2005 12:47 am
Hey guys,
A couple nights ago, I dropped the HUD cluster into my RMS13 with mixed results. In fact, I was surprised at just how much of the cluster worked! All the indicator lights, the tach and the turn signals came on without a hitch. However, none of the background dash lights came on, and the tach read about 1000 RPM too high on idle, making it pretty unreliable. More importantly, though, was that the speedometer didn't turn on AT ALL.
I'm not concerned about the digital readout, because I'm ready to make that a little side project for the coming weeks/months. What worries me is that the odometer, which is directly connected to the speedo, didn't log any distance at all in the course of a 15 mile drive.
The CEL came on, I assume because the engine was under load and according to the odometer, we weren't going anywhere! I swapped the analog cluster back in and the CEL went off after about 1/4 mile, and the odometer read normally, as did the tach and speedo. Also, the nighttime illumination worked fine.
HUD problems aside, what do you guys think could be the issue? Based on my observations after swapping back to the analog cluster, I'm pretty sure I don't have any defective sensors or blown fuses. I've checked the digital cluster's subharness, pin for pin, and there are no shorts or breaks. I found ONE break in the printed circuit, and it's between two of the illuminating bulbs... I assume that this is why the lights didn't come on when I switched to my parking lights , LOL, but it doesn't explain the disconnect to the speedo unit.
