Analog Instrument Cluster => HUD Instrument Cluster Swap; Questions
masticatingcow
Car: 94 Mazda FD3S
Hey NICO,
I've done some searching and have not found any threads that really go over how simple or complicated this swap is. Has anyone done one? If so, what parts are needed besides the cluster? Can it be installed without the HUD unit and still display speed in the dash?
slow s13
Car: cars, photo, music
All you need is the small sub harness that goes between the cluster and car. Yes you can run the digital cluster without the HUD.
masticatingcow
Car: 94 Mazda FD3S
Thanks, slow s13. By between the cluster and "the car" do you mean the cluster and the main harness? I haven't been behind the dash yet, so thus far, I'm working in the dark, and am only assuming the subharness will connect directly to the existing main harness.
wangless
Car: '02 MBP WRX
when you take out the cluster theres a harness connected to the cluster. follow them back to 2 connectors, one is easily accessable, the other one is like in the center of the dash, underneath. gotta have some small *** fingers lol.
anyway, where you getting the cluster ?
masticatingcow
Car: 94 Mazda FD3S
I haven't purchased one yet, but I wanted to get an idea of how easy or hard it would be to make the swap. As much as I hate to say it, I think eBay is going to be my best option. Everyone I know with a HUD has serious problems with them, and while buying on eBay is still a gamble, it's better than paying out for something you KNOW needs serious work.
azncorruptedo17
Car: 1991 Nissan 240sx SE
hmm... does anyone know if the HUD will work on a SOHC? or does it matter?
masticatingcow
Car: 94 Mazda FD3S
Nissan made HUD dashes for the 89-90 coupes, so if you can get ahold of one of those, then I would assume it would be just as straight forward.
Modified by masticatingcow at 7:14 PM 1/15/2005
masticatingcow
Car: 94 Mazda FD3S
http://cgi.ebay.com/ebaymotors...=WDVW
Here is an eBay auction for an 89-90 HUD cluster.
wangless
Car: '02 MBP WRX
thats WAAAAAAAAAAAAAAY to risky. fuctionality UNKNOWN. and plus, the tach wont work, its a sohc.
i THINK, you can put your analog tach on the digi cluster, but it might be the other way around. someone asked about this last month or so... and i posted about it lol. i completely forgot though.
search ??... i might just go back through my subbed topics though
masticatingcow
Car: 94 Mazda FD3S
wangless wrote:thats WAAAAAAAAAAAAAAY to risky. fuctionality UNKNOWN. and plus, the tach wont work, its a sohc.
Yeah, wangless, you CAN swap the analog tach into the digital cluster. And actually, I was just linking it for azncorruptedo17, who asked if one could swap a HUD unit into a SOHC car.
The DOHC and JDM CA and SR units actually seem easier to find, though...
wangless
Car: '02 MBP WRX
so you CANT swap the digi tach to the analog tach ?
masticatingcow
Car: 94 Mazda FD3S
Well, I would assume that the logic would work both ways. Of course, that's a big assumption to make, but knowing that the tach operates independently of the rest of the cluster makes that assumption pretty solid.
black s13
sohc and dohc speedos are the same, works on both. the tacks are interchangable within generations, ie dohc to dohc and sohc to sohc. the sohc tack is smaller, and most likely would look stupid in a dohc cluster. dohc tach in a sohc cluster blocks the outside "dashes" of the tach, all you can see is basically the number.
wangless
Car: '02 MBP WRX
youre not online cow... so heres a better cluster
http://cgi.ebay.com/ebaymotors...62810
ruthlesstyper
black s13 wrote:sohc and dohc speedos are the same, works on both. the tacks are interchangable within generations, ie dohc to dohc and sohc to sohc. the sohc tack is smaller, and most likely would look stupid in a dohc cluster. dohc tach in a sohc cluster blocks the outside "dashes" of the tach, all you can see is basically the number.
sorry to say this but the is wrong. When i swapped my sr i had to swap a dohc tach into my sohc. They are both the same size....
black s13
dohc tach face is defenitly larger than sohc tach face, so much so that it annyoned me to the point of swapping tach faces. ie i have a dohc tach "motor" with a sohc tach face, just so it fits properly in the sohc cluster.
eidt: or maybe the size differance is between HUD and non HUD? all i know is non hud dohc tach is considerably larger than a hud sohc tach.
wangless
Car: '02 MBP WRX
analog tachs are the same, regardless of sohc or dohc
analog compared to the digital tach is different
wotandsdwys
Car: 1992 240SX
for some reason when I tried to swap my clusters between my 93 SE coupe, and 92 base hatch, the digital cluster did not work in the hatch.
everything was fine, except the digital speedo got a tach signal, and would raise and lower with my RPMs. And I used the subharness.
But the analog cluster worked fine in the coupe.
masticatingcow
Car: 94 Mazda FD3S
Yeah, that's bizzare. Welcome to NICO, mighty thread necromancer! I hope we can help!
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Holy thread revival, Brother!!!
Thats a first one for me, if it work in one car and you are using the same assemblys (cluster,harness,etc..)it should work in both cars...the only thing I can see causing this is that one of your cars is DOHC and the other SOHC....possible swap??? or possible wiring problem...??? I see the years of the cars are '92 and 93'....so that makes it both DOHC's.....YOur cluster is for a DOHC and they were designed and an option on the coupes only....I will say try to get another cluster and try it again on the hatch...
OH, Welcome to NICO, man......
project240.info
Car: Nissan 240SX Convertible
I am confused. Can somone tell me if this will work?
Swapping out HUD in 92 vert with analog from 90 coupe?
I have all the wiring from both cars.
Thanks.
(can I swap the tach from the dohc hud cluster to the analog sohc cluster?)
Modified by project240.info at 9:44 PM 8/1/2006
project240.info
Just so you know, you can swap the tachs, the face is smaller. you can swap the faces.
(Swapping out HUD in 92 vert with analog from 90 coupe works!)
Modified by project240.info at 11:08 AM 8/6/2006
