DanCouga »
https://forums.nicoclub.com/dancouga-u26784.html
Sun May 01, 2005 1:00 pm
I got bored and went sunday shopping today and picked up a new head unit for the 240. When I got home I figured I should go ahead and bypass the factory amp. I read the FAQ posted on 240sx.org and was kind of dissappointed, no offense to the original author. So I figured I would go ahead and try and update it a little.
My method is a 'no turning back' method. The original method you could probably splice back in the factory amps if you needed to, for mine to work you will have to be a little destructive and remove the connector from the amp.
Step 1 was of course drawing up the schematic, which wasn't hard at all, the board is laid out fairly well and most things are labeled.
We'll start with Amp 1(the one with the larger connector). You have 15 pins(3 of which you will never need ever again. ever). You have an input for left and right and two outputs for each. This number is higher than the original FAQ because it did not include information on the pillar mounted tweeters. Once you have written down what each pin is and desoldered the connector from the board, you'll need something to put it in. You can get a small solderless bread board or a blank circuit board. All connections will be left to right, top to bottom while looking at the connector with the longer pins on the top. You should have 3 long pins and then a gap of 2 blanks and then another set of 4 pins, the bottom row should have a group of 6 pins with 1 blank followed by 2 pins. You need to jump 1-3-6 for left + and 8-10-14 for left negative. 2-7-12 for right + and 9-11-15 for right -
That's it. The other wires on this connector are power, ground and the remote wire.
I'll post the second half once the nyquil I'm drinking wears off.
