an interesting find on clutches....
McAdam
Car: I like cars and my motorcycle. boats are fun too
hey all,. i dont know if this has been covered here or not, but I was ripping apart a KA24E out of a 1991 nissan 4X4 truck and I found that the clutch is a lot bigger in diameter than on the 240sx KA24E. the flywheel bolt patterns are the same and everything else, just the clutch is huuuuge!! I think its what, 225mm vs 240mm?
I think its a 240mm clutch. it looks the same size as the clutch I took out of my 280ZX 2 + 2. Not to mention the clutch that now resideds in my 280zx came out of a 1985 Z24 powered 4 x 4 truck. if this is true, you guys running yoru turbos could just get a 4 X 4 flywheel and use 280zx turbo clutches. and there are tonnes of performance clutches out there for 280ZX turbos. they are built to withstand a LOT of torque. hi hp L28's are usually even higher torque L28's.
thought Id share, sorry if this is a repeat.
McAdam
Nathan
Trust you to find something cool like this...good one! Now someone who can afford too...try it and see if it works :D
erich
There is a huge thread on this on FreshAlloy. Something about the "White Bunny Special"
StanBo
Car: 93 Mazda Miata
10 Toyota Tacoma
Repeat or not I am listening.
Nathan
So is THAT what the white bunny special is? I always wondered...
SxMachine
Car: Im on a horse
McAdam
well, this is how it works with the Z clutches. the 225 and 240mm flywheels are the same size and weight (23lbs, unless you have an early '70 240Z then it is only 17lbs) just different diameter clutch surfaces. also, I KNOW for a fact that L28E 240mm clutches and Z24I 240mm clutches are one and the same. same bolt pattern, same number of splines on the clutch hub. I needed a clutch for my 280zx and they had just gotten a 85 4x4 in the local j/y with a brand new clutch and a wrecked body. out came the clutch, straight into my 280ZX 2 + 2.
I'll check for sure tomorrow. I have my old 280zx pressure plate and disk. i will attempt to put it on the KA24E truck flywheel and makes sure the bolt pattern is correct. although, nissan being what they are with parts interchangeability and all, I am 99% positive it'll bolt right on.
McAdam
SxMachine
Car: Im on a horse
So the ka truck flywheel does bolt up with no prob.
andrave
Car: 1989 Nissan 240SX Coupe
someone told me about this around 3 years ago...interesting though.
LT_Z
Mike Lee is running 504rwhp/470lb/ft and he is using the white bunny special. But I think the ACT XT kit will hold the same and you can keep your flywheel
SxMachine
Car: Im on a horse
Yeah but an LUK clutch (which is a pretty good clutch by the way) is like $100 or so. Way cheaper than the ACT. Thats the whole point of all this.
StanBo
Car: 93 Mazda Miata
10 Toyota Tacoma
Hmmm see I am not looking for the inexpensive (even though it is good). I am looking for a strong clutch for drifting. It has to be able to take kicks at high rpms without heating up.
I didn't do any clutch kicks with my clutch and the springs failed on me. The face was fine as when we installed it.
The white bunny gives me more options on aftermarket clutches when I turbo the KA.
LT_Z
What is the LUK clutches ? what are the specs ? I need something to hold 550 rwhp & like 500lb/ft
