Holisticbeatz »
https://forums.nicoclub.com/holisticbeatz-u5589.html
Sun Jun 15, 2003 10:03 pm
When my friend finished with my car, he called to fill me in good news that the car was running better than ever. The clutch was engaging crisply, the sticky clutch pedal was a thing of the past, and power transfer from the engine to the rear wheels was torque happy. It was a short-lived moment however. A few days later when I was driving to Kragen Automotive, my car once again seized up. Not making such a wise decision at the time, I attempted to turn around and drive back home. I came to a stop at a red light, and then try to launch the car when it turned green only to move at a snail’s pace while revving up to 5,000 RPMs! Frustrated and angry, the car was barely moving 6 inches per hour. A minute after driving Goldie like that, I started to notice the distinctive burning odor of clutch disc in the cabin of Goldie. At that very moment, my heart just dropped to my stomach and I felt numb all over. Goldie’s clutch was fried again!
I was so pissed off that day. I was ready to take out my Calloway Big Bertha driver and start bashing the hell out of Goldie. I’ve had nothing but a string of bad luck since it’s maiden voyage home. I had already spent roughly $600 on labor and parts for a clutch that has failed on me twice. Later on that week, I got news that a friend of mine from high school recently opened up an auto repair shop. I remember working with him in 4th period auto shop class. Everybody knew he was going to be a mechanic, and sure enough that’s what he became. He has been in business for a month already, and judging from the hustle and bustle at his shop, he’s not doing so badly at all.
I called him up and talked to him about my situation. He told me to have Goldie towed down so he can check it out. I told him about the problems I have been encountering for the past 2 months and he recommended that I have the clutch changed again. Once he had the transmission removed, I saw the damage that I had done. The 2nd clutch disc was just flattened. I did, what it would take 1-2 years of normal driving to wear out a clutch disc in 5 minutes. Inside the bell housing after the transmission was removed, I saw clutch disc shavings from the abuse I inflicted. When I revved the hell out of the motor, I punished the flywheel so bad, that when my mechanic removed it from the block, we saw the hot spots that formed and a heat fracture near the center. Moreover, when I was analyzing the pressure plate for it’s grabbing capacities, I saw that there was still some grease. Even though it appeared that the pressure plate was carefully sprayed by brake cleaner, there was a residual build up that clung in the hard the reach spots in the pressure plate from the previous installation. Low in funds, I decided to purchase an OEM clutch from the dealership, and then have that installed by my mechanic. According to a phone call from my mechanic on the last Saturday of May, the installation was successful. Since it was near closing time, he had no time to test drive my car. He told me that I should check back on Monday for the status on the clutch situation.
Monday, the 2nd day of June came rolling by. I received a phone call early in the morning from my mechanic full of not-so-promising news. I quickly jumped out of bed and left the house in 15 minutes. I rushed down to his shop only to see Goldie parked in the corner. I asked him what was the status, and this is what he said. “I warmed up the car till the temperature needle started to move. The clutch was just fine while I was doing some normal driving around the block. Then when I came to a stoplight, the shifter froze up and I couldn’t get into gear. I turned off the car, got into gear, and then I restarted the car only to have it lag during the launch. I towed the car back to the shop and I think I will have to remove the transmission again to see whether or not I did it correctly.”
While he was sitting in Goldie, he was tapping the clutch pedal and trying to shift. He said out loud, “how strange, the clutch pedal got hard again.” Then it hit me, I asked why the clutch pedal had no free play. I kept thinking what a strange clutch it was, because it would only grab when the pedal was 1-2 inches from being fully released. Normally, on a Honda, the clutch would grab once the pedal was halfway from being released. I then recalled asking a technician at the dealership regarding clutch engagements and he told me that its normal that the 240SX’s clutch would grab near the top. Since I had an incident with bad advice from the dealership, I completely disregarded everything that was said to me and went with my own gut instincts.
I then decided to further investigate the lack of free play on the clutch pedal. I found myself underneath the driver side of the dash looking up towards the push rod of the clutch master cylinder. One look at it and I knew it was installed incorrectly. The U-shaped clevis pin holder of the push rod was adjusted way too far forward. I was in utter disbelief when I saw it. I was an idiot to just blindly assume that work from the dealership was done correctly. Bringing this to the attention of my mechanic, it gave us a partial answer to the clutch riddle. The car runs fine when cold, but starts seizing up when warm. What could it be? After awhile of tinkering, it turned out that the U-shape clevis pin holder needed adjustment. It needed to be twisted back towards the middle of the treaded portion of the clutch master cylinder push rod while the car was running at operational temperature. The car was allowed to idle for about 20 minutes and then driven. With that fixed, the car drove perfectly. All the symptoms the clutch suffered from the previous installations were gone. Also, there was a 1-inch free-play on the clutch pedal that improved the feel and engagement of the pressure plate.
