<sigh>
Your cooling system is MORE than sufficient if it's maintained properly. I guarantee you that... We see heat here that'd make you guys cry.
Why not simply bypass the coolant past the intake manifold? Simple.
Get your cooling system back to its original efficiency first. Coolant flush, radiator pressure test, new cap, new thermostat, clean the radiator fins (and all the crap from between the condensor and radiator), make sure your fan clutch works properly, ensure function of overflow system, and use a 90% distilled water / 10% coolant (NOT 'coolant mix') mixture with 2 bottles of Redline Water Wetter.
No need to mod something that was designed right.
p.s. Your radiator wasn't designed for reversed flow, and even if it was, gravity is pretty irrelevant in a sealed system.
