ss82480 wrote:Well to give you a little help here. I had the above mods + an underdrive pulley and bc stage 2 cams. Put about 160whp and tq, with 180ish psi compression. You will be disappointed, boost it!
something like this is exactly what iwas looking for, yea im going the route of boost
already got the t25 and ready to rebuild it so by the time it comes to install everything will function good
Ajax wrote: Okay, so I'm not really into drifting- I've got respect for the car-control skills, but not really my thing.Question- would you want a light flywheel? It seems to me that unless you're pushing plenty of power that you might want to have the extra force from a heavier rotating mass. But like I said, drifting is not something I'm really familiar with.
yes you are right...having a heavy stock flywheel is good for initiating a drift cause the more rotating mass brings more "upset" to the rear end
a lightend flywheel would yes be harder to initiate but the trade off is you have more responce to maintain a drift
to compensate for the trade off a better pressure plate and clutch combo grabs harder and forces harder to create that same "upset" with the added benifit of having better responce
edit: and that only has to do with clutch kick and shift lock initiation drifts
there are various other techniques such as feint and e brake that the flywheel being heavier or lighter has nothing to do with the actual initiation
