Amplifier / Subwoofer Disconnect
Post all your Nissan electronics, car audio and stereo questions here!
Kinesthesia
Right now I have a large Sony Amp and heavy dual 10" sub box in my trunk. I'm about to start autocrossing, and I'm trying to figure out a way to make a quick disconnect for the amp power.
The idea being, I'll mount the amp onto the sub box, and then I could just disconnect the power and the RCA's and just pull it out for a race.
I've tried everywhere... stereo store, Pep Boys, hardware store... trying to find a decent connector for 8 gauge wire that is insulated (so the hot wire doesn't flop around and spark).
I considered two fuse blocks, one for hot and one for ground, but that's expensive and clumsy, I think.
Any ideas ?
Worst case, I'll leave the amp in and just pull the sub box but I'd prefer to pull both.
Thanks
Rex
Car: None
Look at something along the lines of what is used in racing for a quick change battery. It still might be pricey, but it should give you what you're looking for with out using dual distribution blocks.
Something like this
Also, look here.
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
I would just make the box quick release. The amp cant weigh more than a couple lbs
Kinesthesia
Wow, what a great idea ! I might just order a pair.
Or, I might just do the box but I kinda wanted to put the amp on the box anyway to get it off the floor of my trunk.
