Yea i figured that.....im assuming you ran the RCA/Remote cable through the center consol out to the back then cut a hole through the carpet? (assuming ur amp is under the passanger seat)Z_Fanatic wrote:Also, don't run the RCA's and the power cables next to each other, it can cause interference.
I have the same setup. Problem is my amp doesnt allow my passenger seat to lock in place when its sitting too far back, so sometimes if i have to slam on my brakes the person in shotgun goes for a ride! lolelninoloco7 wrote:So i plan to install an amp/subwoofer. The amp is going to be under the passanger seat, but how do i wire the Power cable from the batt. to the inside of the car, its really tough to get it through the firewall. Is there a link/pics i can see how the routing goes?
Exactly what I didZ_Fanatic wrote:There's a hole behind the passenger side fender splash guard for the wiring harness you can snake it through there and into the car, there should be a rubber boot or elbow I poked a hole through it and sealed it up with silicone once I had it where I wanted it. It comes out near the ECU, its a good route because once you get it through the firewall you can pop it out into the engine bay right next to the battery.
ztommyx wrote:i mount mine behind the passenger seat against the vertical black carpeted panel. great place to put amps there
