Amp
Joker69
Car: 2008 Nissan Versa S Sedan, 1978 Datsun 280Z 2+2, 1983 Mercedes 300SEL, 1997 Eagle Talon
Does anyone have pictures of how they ran their 12v+ wire for their amp, and how they did it? I dont know where to drill for the damn thing. Thanx!
jfanaselle
Car: 2007 Nissan Versa Hatchback SL, 2008 Nissan Rogue SL
If you search for amp or amplifier install, there isn't any info about penetrating the fire wall. However, there is a great tutorial from Clipsed on how to install foglights and he covers how to get through the fire wall. http://www.nicoclub.com/articles.php?id=262175However, I tried tried to do it this way and I couldn't get a 4 gauge through the big rubber grommet. I actually removed the battery, removed the stock air box, unbolted the ECU and moved it to the side (without actually unplugging it) and was able to expose a large enough area of the firewall to drill a hole. There was actually a small spot that was already depressed (like it could be punched out for wiring if necessary) and I just drilled it out. Sorry I don't have pics, but hope that helps.
Joker69
Cool, muchas gracias, im gonna go try it right now, ill be back and say if it worked for me or not!
jfanaselle
Did you ever get it installed?
Joker69
Sorry, i was almost late to my moms graduation so i couldn't get back on. but i ran it, and it sounds a hell of a lot better with a 4 gauge, than the 18 gauge temp. wire i was runnin, not only that but my fuse dosn't blow out every 3 minutes when i raise the volume passed 9. still waitin on my dash kit, but i will post some pics later. thanx!
Jemdawg
Car: Super Black Nissan Versa 1.8SL Hatchback
Wow! 18 gauge power wire? That sounds like it was a fire hazard, how many watts are you running?
