NY.AD.MAN »
https://forums.nicoclub.com/ny-ad-man-u71077.html
Wed Nov 28, 2007 6:51 am
The reason why I always suggest a capacitor is as such:
The system with incur influxes of power whenever it is needed; i.e. a strong bass hit, the start of a loud song, or even just a lull in the wattage due to varying tempos and rhythms (continuous amount of power on held notes, wavering on rock that includes more drum beats)
- The capacitor is NOT a fix, I understand, I do installs and I understand that, through countless retorts, that capacitors are a "band aid"
BUT
- There is always a risk involved with aftermarket products (stereo-wise). In order to get more sound and clarity, you need more power (yes, some companies are more efficient, blah blah...), but what makes a capacitor worthwhile is the "return to equilibrium" of the system.
By adding a capacitor, you are NOT diminishing power drain, just making the power drain more fluid and actually improving the response of the subs and the speakers all the same! You decrease the amount of delay in the subs, cleaner hits and better sound quality due to adequate power reserves.
SO,
Before everyone starts crying "foul", think about the continuous nature of the power. Your stock wiring from Nissan is strong enough to handle the load, but you DO NOT want to push it!
