bigE »
https://forums.nicoclub.com/bige-u7035.html
Fri May 30, 2003 10:11 am
Your Amp is clipping, it goes into a protection mode to shut itself off, before destroying itself. You have a couple of problems,
First, you need to have an inline fuse, to protect your amp, it sucks having to go buy a new amp because you fried it by not running an inline fuse, they generally aren't too exspensive, you can pic one up at your local stereo shop for a couple of bucks.
Second, your ground wire generally needs to be the same size as your power wire, plus 16 gauge, I run 12 gauge speaker wire.
Third if you want our help, we need to know model numbers, what model amp and what model sub. Most likely you have a 2 channel amp, probably not stable in mono at 2 ohms, you also most likely have a single 4 ohm voice coil sub, so when you you bridge the amp to run the sub in mono, your cutting the impedance of the sub in half when bridging it so the amp sees a 2 ohm load, which your amp most likely can't handle.
Sometimes you can run an amp in mono at 2 ohms thats not meant to be, but if you are, your gonna wanna add an inline fuse, bigger ground wire, and cut the gain down on the amp. Find out the model of both the amp and sub, and also the impedance of the sub, and we'll be able to help you out a little better.
Eric
