xekushnr »
https://forums.nicoclub.com/xekushnr-u16901.html
Mon Feb 11, 2008 7:21 pm
I'm guessing the gain is turned all the way down. What you need to do is turn the volume on the radio up to 3/4 full or so. Then, start slowly adjusting the gain up. If the amp has a switch for an LPF (low pass filter), turn it on. Just make sure you set the LPF frequency at least half way up the knob so it wont cut off some of the low frequencies. Once you hear the sub start to distort due to amplifier clipping, turn the gain down a bit. You will probably want all the bass settings on your radio down all the way since your sub will be handling all the bass duties and I'm sure you know that bass + volume in midrange speakers = distortion. Make sure you never turn up the bass settings off the radio or amp after you tune it and you should be fine, assuming that the amplifier has more than enough power to drive the sub.
