amp location help please
All things Altima Coupe.
olikemystyleo
Car: 2008 nissan altima couple all blacked out
where is the best place to put my amp in a 2008 altima coupe so that it is out of the way
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Attach it to the back of the rear seat?
Rolling Estonian
Car: 2008 Altima Coupe 2.5
the best place would be to remove the spare tire and put it there. I personally couldn't do it, too scared.
olikemystyleo
can i cut out the foam and put it in there or u think its going to ova heat and longbeach contract me
LongBeachCoupe
2005 Lexus RX
i dont think theres any overheating issues... and im guessing you mean contact you lol.. your on my facebook, and my numbers there.. gimme a call! Hahha santas confused!
Rolling Estonian
olikemystyleo wrote:can i cut out the foam and put it in there or u think its going to ova heat and longbeach contract me
Most amps have a minimum air space around the amp, as long as you cut the foam out large enough to accommodate that air space you'd be ok.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
I agree 100%
AppleBonker
Just make sure you know what you are mounting too. If you're going to go right to the metal trunk floor, be careful not to bolt/screw into anything important. Also, be sure to weather seal so your amp doesn't get wet.
My sub amp which is installed under the floor of my trunk has minimal space (maybe about 1" in front/back and about 1" on top) and I've had NO overheating problems. It also depends on the type of amp you have. A class D amp will generate less heat than A/B, so keep that in mind too.
