that 8 gauge kit will do you just fine you won't have any problems with it as long as you install it correctly.xagna wrote:I have a car amp that is 100W capacity and has two 25A fuses.I accidently cut the wire that goes from this amp to the battery in the engine room so I need to reconnect.
I am thinking about buying this amp intallation kit which has 60A AGU fuse.
http://cgi.ebay.com/8-Gauge-Am...wItem
Can I use 60A AGU fuse with this amp?
I was thinking the same thing. It could be an Mmatts and stable to .5 ohm? Anyhow, with a true 100w amp, the biggest fuse you'd need is 15amp and 10ga wire. (Watts/volts=amps)PoorManQ45 wrote:HOloy crap. two 25a fuses on a 100w amp! May be a bit underrated
