amp help..?
jpoland1228
Car: 08 Altima coupe 2.5s
im still a little hazy on matching subs up to an amp... im buying a zenclosure with these subs.. http://www.crutchfield.com/p_13610W0V24 ... tml?tp=111 there 2 10's so i need 600 watts and 2ohms? can someone send me a link on one i can buy oneline for a good price! thanks in advance
also does sony make any good amps.. if so which one
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
These are 4 ohm subs, so you can wire them in parallel and take your total impedance load down to 2 ohms. This is formula for parallel wired subs.
(r1 X r2) / (r1 + r2) so 16 divided by 8 is 2 ohms.
Honestly those subs arent going to handle much more than 1,000 watts total, they are JLs entry level sub I believe. Go somewhere in the range of 600-800 watts and you will be fine.
Dont buy Sony...
