evildky wrote:the wiring in these were screwy when new, I'd go around with a brass bruch pull and clean all your grounds, and see if ti clears thing up a bit, also the switches can be an issue you can take them apart and clean them as well, just a PITA
thanks for the advice. i cleaned up my grounds and connections but the gauge will still twitch when i play with my lights. however, when i'm revving it won't move. is that normal? i know the amps should differ when putting a load on the electrical system, but i don't want to blow myself up by driving around a dangerous car.
