the converted »
https://forums.nicoclub.com/the-converted-u57671.html
Sat Nov 03, 2007 2:32 am
Are you trying to hook up an ammeter? Assuming that you are there is no factory wire to hook into. You'll need to hook up a shunt to measure current flow under the hood and run a wire from that to the gauge. Hook up 12v and ground and your good to go. To be honest they are kind of not worth it and a simple voltage gauge can do the trick just fine.
